im really love your work. thanks for effort. i want show battery levels for persons. I need help for it.
@Mattias_Persson so I was able to implement the code into the button_card_templates.yaml but it took some splicing of other portions of your code to make it work AND scaling properly for mobile. Thanks for the help!
For anyone wanting to use mini-graph-card as a button card, the code is below:
# TEMPERATURE #
temperature:
template:
- base
show_name: true # Hides Card Name
show_state: true # Hides Card state
state_display: >
[[[ return ' '; ]]]
custom_fields:
circle: >
const temperature = Math.round(entity.state);
return `<svg viewBox="0 0 50 50"><circle cx="25" cy="25" r="20.5" stroke="#313638" stroke-width="1.5" fill="#FFFFFF08" style="
transform: rotate(-90deg); transform-origin: 50% 50%;" />
<text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle" dominant-baseline="middle">${temperature}°F</text></svg>`; } ]]]
graph:
card:
type: "custom:mini-graph-card"
height: 140
hours_to_show: 24
points_per_hour: 1
line_width: 8
font_size: 75
decimals: 0
show:
icon: false
state: false
legend: false
labels: false
labels_secondary: false
points: false
color_thresholds:
- value: 0
color: "#276696"
- value: 69
color: "#228C22"
- value: 75
color: "#d35400"
- value: 76
color: "#c0392b"
styles:
custom_fields:
graph: [bottom: 0%, left: 0%, width: 128%, position: absolute, margin: 0% 0% -13% -14%]
icon:
- width: 67%
- fill: "#9da0a2"
circle:
- display: initial
- width: 90%
- margin: -6% -5% 0 0
- justify-self: end
- opacity: 1
ui-lovelace.yaml
# BEDROOM #
- type: grid
title: Bedroom
view_layout:
grid-area: bedroom
columns: 2
cards:
- type: custom:button-card
entity: sensor.bedroom_temperature
tap_action: !include popup/bedroom_temperature.yaml
hold_action:
action: none
custom_fields:
graph:
card:
entities:
- entity: sensor.bedroom_temperature
color_thresholds:
- value: 0
color: "#276696"
- value: 69
color: "#228C22"
- value: 75
color: "#d35400"
- value: 76
color: "#c0392b"
- entity: sensor.nightstate
color: gray
y_axis: secondary
show_line: false
show_points: false
show_legend: false
show_labels: false
template:
- temperature
- icon_temp
entity: binary_sensor.bedroom_occupancy
tap_action: !include popup/bedroom_occupancy.yaml
template:
- base
- icon_occupancy
Hi!
First I want to thank all of you for putting all these code up here and helping each others.
I’m trying to use the footer to show how many of my batteries level are under a certain threshold.
But I’m not really good at javascript so I tried to do it in jinja2.
But the problem is that even though I convert it to integer, it seems to not recognize is at integer.
the code is like this.
How come?
Is it possible to make this in javascript?
{% set ignore_entities = ['sensor.bass_boss_battery_sensor','sensor.lenovo_tb_x306f_battery_level'] %}
{% set test = states.sensor
| selectattr('attributes.device_class', 'defined')
| selectattr('attributes.device_class', 'eq', 'battery')
| rejectattr('entity_id', 'in', ignore_entities)
| map(attribute='state')
| reject('in', ['unknown', 'unavailable'])
| map('int', -1) | select('le', 60)
|select('ge', 0)
| list | count
{% if test == 0 %}
{% else %}
{{ test | int }}
{% endif %}
You can use this template by replacing === 'playing'
with < 50
or something like this
let list = [],
exclude = 'sensor.test_battery';
Object.keys(states).forEach(key => {
let device_class = states[key].attributes.device_class,
state = states[key].state;
if (key !== exclude && device_class === 'battery' && state < 50) {
list.push(key);
return list.length;
template: person
custom_fields:
circle: >
let battery = states['sensor.iphone_battery_level'];
if (entity && battery) {
let stroke = variables.state === 'home' ? '#b2b2b2' : 'none',
fill = variables.state !== 'home' ? 'rgba(255,255,255,0.04)' : 'none';
return `
<circle cx="25" cy="25" r="20.5" stroke="${stroke}" stroke-width="1.5" fill="${fill}" />
<text x="50%" y="54%" fill="#8d8e90" font-size="14" text-anchor="middle" alignment-baseline="middle" dominant-baseline="middle">${battery.state}<tspan font-size="10">%</tspan></text>
</svg>
Anyone receiving this error?
Error: Failed to execute ‘define’ on ‘CustomElementRegistry’: the name “mod-card” has already been used with this registry
Been searching around for a solution and no luck so far.
I did come across that thread but if I’m following what’s mentioned correctly, that specific issue which caused this same error as well was fixed. I was assuming it was something related with how I setup your Lovelace dashboard (which is awesome by the way) but after digging around I’m at a loss. I’ll maybe reopen that issue over on the card-mod repo to see if there’s a solution.
perhaps someone that uses Plex is interrested, i make a workaround for the Recent Plex Widget, with this its possible to show only the “last added unwatched Movies”, and not the “last added Watched / unwatched Movies”.
add a sensor template in your configuration.yaml
sensors:
plex_unwatched:
value_template: "{{ states('sensor.plex_recently_added_movies') }}"
attribute_templates:
data: "{{ state_attr('sensor.plex_recently_added_movies', 'data') | selectattr('flag', 'defined') | selectattr('flag', 'eq', true) | list }}"
and then add the name of the sensor in die ui-lovelance “sensor.plex_unwatched”.
thats all, now you have the latest unwatched movies.
Hi @Mattias_Persson, great ui! I’ve been trying to replicate this for my needs, but I’ve run into a problem. The conditional media card does not work at all. I triple checked the code, but no errors in the physical code. The error I’m getting does explain what’s wrong, but even when I try to fix that, the error persists. My limited knowledge of ha is keeping me from figuring out what is wrong.
Here is the error:
Thanks!
Thank you. I am not using your files at all, but that info pointed me to some docs about CSS (of wich I have no idea until now :).
I managed to make my own “grid”, but the spacing among the groups of cards does not work even using the CSS documentation.
It appears that it ignores that part
type: custom:grid-layout
layout:
column-gap: 5px;
row-gap: 10px;
grid-template-areas: |
"sidebar card01 card02"
"sidebar card03 card04"
"sidebar footer footer"
Also grid-gap:
does not work.
Is HA overwrites this someplace else?
Progress so far:
This is one of the group that contains 4 cards:
- type: vertical-stack
title: Bathroom
cards:
- type: horizontal-stack
cards:
aspect_ratio: 1
color: auto
color_type: card
entity: switch.livolo_bath_right
icon: mdi:wall-sconce-flat
haptic: success
hold_action:
action: more-info
show_last_changed: false
show_state: false
state:
- styles:
card:
- filter: opacity(50%)
- background: dark gray
- font-size: 18px
- color: white
icon:
- filter: grayscale(100%)
value: 'off'
- styles:
card:
- background: white
- filter: opacity(80%)
- font-size: 18px
- color: gray
icon:
- color: gray
value: 'on'
card_mod:
style: |
ha-card {border-radius: 15px;}
aspect_ratio: 1
color: auto
color_type: card
entity: switch.livolo_bath_left
haptic: success
hold_action:
action: more-info
show_state: true
state:
- styles:
card:
- '--mdc-ripple-color': gray
- '--mdc-ripple-press-opacity': 0
- font-size: 18px
icon:
label:
- font-size: 14px
value: 'off'
- styles:
card:
- background: white
- '--mdc-ripple-press-opacity': 0.2
- font-size: 18px
- color: gray
icon:
- color: gray
label:
- font-size: 11px
value: 'on'
card_mod:
style: |
cards:
- type: custom:mini-graph-card
color_thresholds:
- color: '#039BE5'
value: 10
- color: '#0da035'
value: 25
- color: '#e45e65'
value: 30
entities:
- entity: sensor.ewelink_th02_temperature
index: 0
hours_to_show: 24
points_per_hour: 1
refresh_interval: 120
align_state: left
show:
icon: false
icon_adaptive_color: true
name_adaptive_color: false
points: false
labels: false
title: Outside °C
card_mod:
style: |
aspect_ratio: 1
color: auto
color_type: card
entity: switch.sonoff_zbr3_02
haptic: success
hold_action:
action: more-info
show_state: true
state:
- styles:
card:
- font-size: 18px
icon:
label:
- font-size: 14px
value: 'off'
- styles:
card:
- filter: opacity(60%)
- background: white
- font-size: 18px
- color: gray
icon:
- color: gray
label:
- font-size: 11px
value: 'on'
card_mod:
style: |
view_layout:
grid-area: card01
card_mod:
style: |
ha-card {margin: 20px;}
Thank you
ps.
I do not use reference files since my UI is rather simple.
Hi @Mattias_Persson
great UI, thanks for effort
How do I get these button cards centered in a vertical stack. I am trying to make a vertical stack with cards to navigate through different views on my dashboard
view_layout:
grid-area: sidebar
cards:
entity: sensor.template_sidebar
template: sidebar
- type: conditional
conditions:
- entity: input_boolean.laundry_display
state: 'on'
card:
entity: timer.laundry
template: laundry
cards:
icon: none
template: sidebar_navigation
icon: none
icon: none
icon: none
sidebar_navigation:
color: '#9da0a2'
styles:
grid:
- grid-template-areas: '"n"'
- grid-column-gap: 0.3em
name:
- font-size: 1em
- letter-spacing: 0.015em
card:
- color: '#9da0a2'
- border-radius: 0.6em
- padding: 1em 1em 1em 1.2em
- width: 13em
- font-size: 1.06em
- font-weight: 500
- background: '#FFFFFF10'
- height: 3.5em
icon-only:
show_name: false
color: '#9da0a2'
styles:
card:
- color: '#9da0a2'
- width: 4em
- height: 3.7em
Firstly thanks for last reply. I tried graph code but i think i miss something, i just change sensor entity
Looks like this
I tried Dev tools but i didn’t understand where im wrong.
ps: I put your code into ui-lovelace.yaml
thanks
That’s just what the sensor card looks like. I hid those elements with card-mod
card_mod:
style: |
.header, .value, .measurement {
display: none !important;
also present in the sample
use card-mod-helper and you’ll get this
#view>hui-view>grid-layout$#root>hui-vertical-stack-card$#root>hui-vertical-stack-card$#root
so, add this under SIDEBAR LAUNDRY TIMER
in themes.yaml
grid-layout$hui-vertical-stack-card$hui-vertical-stack-card$: |
#root {
align-items: center;
Try grid-gap
again without putting a ;
at the end (it’s valid css but not yaml)
@Quinnod34 @Pablo_Gustavo_Fiscel
pm me your ui-lovelace.yaml
and button_card_templates.yaml
and I’ll have a look
I’ve never encountered that error. Are you sure you’ve updated card-mod to latest and cleared browser cache on your devices?
I found the problem but not the solution. The Plex Recently Added sensor appears online but data is empty. When I find the problem I know I will be able to correct the rest. I already learned a lot with your repository. But I am stuck with this problem. Thanks for answering.
U r golden
Still trying to decipher your yaml’s…
