After a 2nd time SD card crash I’m looking for better alternative.
I’ve ordered mSATA adapter for RPI, but just wondering if this is a good direction - as I read there are some issues with installation…
Anyway, requirements: SSD, LOW power consumption, Ethernet port,… rest = optional.
It will run only ‘hass.io’. So no special additional features…
Any recommended hardware?
P.S. I have not used ‘Dell Optiplex 780’ USFF, but the power consumption is rather high = 180W.
That, or install the release candidate of HassOS (which supports USB boot) on an SSD. Just converted to that from my Hassio on Raspbian setup this weekend, works great.
Looks promising - so I need the latest image …RPI3 image… and then ‘etch’ it on mSATA (SSD)? Right?
‘Release candidate’ means it is still not stable version…?
I grabbed a NUC on eBay for around $200 USD. Figured if I was going to entrust my entire home’s automation platform to a single system that spending a little more than I’d have liked would be ok.
I believe that the 32 GB minimum is a recommendation passed around related to SD cards and wear. A larger SD card does not need to reuse the same space as often as a smaller card, therefore reducing wear (and wear is a concern).
With SSDs, wear isn’t really a concern. The SSD should be sized based on the use case. Im using around 12 GB for my entire setup and I will never come close to needed 20GB much less 32GB. Someone with a larger setup or keeping history longer may need much more room.
ooo… nice. I got all the hardware, wasnt ready to move to hassbian for HA.
Gonna wait until it hits release then switch right over. Its been super stable for me atm, but I worry about the SD wear…
couldnt get SSD working with HassIO due to USB boot not neing available. Which would mean i would have to move to hassbian to get SSD working, I dont really want that, hence my excitement.
Today arrived my mSATA bay for my RP3+.
This week I also expect used 32GB mSATA SSD ( considered 64GB, but 32 was much cheaper ).
Then I try to install ‘hassos’…
Today received mSATA disc. But I have problem to ‘image’ it with ‘Balena’.
After 1 min. error is showing…
I’m doing that via X850 borad (with mSATA disc plug-in) connected with USB cable…
As I do not have other converter - is that any limit/problem doing the ‘etching’ via X850???
Some instruction from web is saying that this should be no problem…
