Hi
I have a Paradox Alarm system and I integrated to HA with this setup
In the configuration.yaml I have the following
alarm_control_panel:
- platform: mqtt
state_topic: "paradoxdCTL/hassio/Arm"
command_topic: "paradoxCTL/in"
payload_disarm: '{"password":"0000","Command":"disarm","Subcommand":"0"}'
payload_arm_night: '{"password":"0000","Command":"sleep","Subcommand":"0"}'
payload_arm_home: '{"password":"0000","Command":"stay","Subcommand":"0"}'
payload_arm_away: '{"password":"0000","Command":"arm","Subcommand":"0"}'
Iknow that I have to change the password to the one I have but I will do it later (I am noob so one step at a time)
I have also setup all the binary sensors and are working ok.
The problem right now is I don’t get the status of the of the alarm in Home Assistant alarm card
but I can get the messages in the MQTT topic. (see below message 71)
I am not sure what I have to type in the subcommand in configuration yaml or what the problem is.
Can someone help a little please?
Listen to a topic
Listening to
Message 98 received on paradoxCTL/in at 11:50 AM:
"password": "0000",
"Command": "disarm",
"Subcommand": "0"
QoS: 0 - Retain: false
Message 97 received on paradoxdCTL/out at 11:48 AM:
"event": 0,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"eventD": "Zone OK",
"data": "R.SALONI"
Message 96 received on paradoxdCTL/hassio/zone3 at 11:48 AM:
OFF
Message 95 received on paradoxdCTL/out at 11:48 AM:
"event": 1,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"eventD": "Zone open ",
"data": "R.SALONI"
Message 94 received on paradoxdCTL/hassio/zone3 at 11:48 AM:
ON
Message 93 received on paradoxdCTL/out at 11:48 AM:
"event": 0,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"data": "R.SALONI"
Message 92 received on paradoxdCTL/hassio/zone3 at 11:48 AM:
OFF
Message 91 received on paradoxdCTL/out at 11:48 AM:
"event": 0,
"sub_event": 4,
"partition": 0,
"sub_eventD": "",
"data": "R.XOL"
Message 90 received on paradoxdCTL/hassio/zone4 at 11:48 AM:
OFF
Message 89 received on paradoxdCTL/out at 11:48 AM:
"event": 1,
"sub_event": 4,
"partition": 0,
"sub_eventD": "",
"data": "R.XOL"
Message 88 received on paradoxdCTL/hassio/zone4 at 11:48 AM:
ON
Message 87 received on paradoxdCTL/out at 11:48 AM:
"event": 1,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"data": "R.SALONI"
Message 86 received on paradoxdCTL/hassio/zone3 at 11:48 AM:
ON
Message 85 received on paradoxdCTL/out at 11:48 AM:
"event": 0,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"data": "R.SALONI"
Message 84 received on paradoxdCTL/hassio/zone3 at 11:48 AM:
OFF
Message 83 received on paradoxdCTL/out at 11:47 AM:
"event": 1,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"data": "R.SALONI"
Message 82 received on paradoxdCTL/hassio/zone3 at 11:47 AM:
ON
Message 81 received on paradoxdCTL/out at 11:47 AM:
"event": 0,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"data": "R.SALONI"
Message 80 received on paradoxdCTL/hassio/zone3 at 11:47 AM:
OFF
Message 79 received on paradoxdCTL/out at 11:47 AM:
"event": 1,
"sub_event": 3,
"partition": 0,
"sub_eventD": "",
"data": "R.SALONI"
Message 78 received on paradoxdCTL/hassio/zone3 at 11:47 AM:
ON
Message 77 received on paradoxdCTL/hassio/zone8 at 11:40 AM:
OFF
QoS: 0 - Retain: true
Message 76 received on paradoxdCTL/hassio/zone10 at 11:40 AM:
OFF
Message 75 received on paradoxdCTL/hassio/zone6 at 11:40 AM:
ON
Message 74 received on paradoxdCTL/hassio/zone9 at 11:40 AM:
ON
Message 73 received on paradoxdCTL/hassio/zone11 at 11:40 AM:
ON
Message 72 received on paradoxdCTL/hassio/zone2 at 11:40 AM:
OFF
Message 71 received on paradoxdCTL/hassio/Arm0 at 11:40 AM:
disarmed
