A "LocalTuya" switch is unavailable, even though it works with "Smart Life."
It’s been a little while since I last looked into my configuration, as everything was working correctly, so it might be something simple.
All my devices appear and work in both Smart Life on my phone and in my LocalTuya module and automations in HA, except for a “faulty” curtain switch. It works in Smart Life, but even though it’s present in the list of my devices in LocalTuya on HA, it’s marked as “unavailable” and doesn’t respond. I have another identical curtain switch that works perfectly.
I’ve restarted my router, my HA router, re-paired my switch, updated… and it’s still the same.
What can I share here to debug this?
Does this make sense?
I also have this notification. I don’t think it’s related to my issue…
"The command line YAML configuration has been moved.
This will no longer work in version 2023.12.0. Please address this before updating
The configuration of the sensor command line using YAML has been moved.
Please refer to the documentation to move your YAML configuration to the integration key and restart Home Assistant to resolve this issue."
By the way, is this kind of warning generic or is it necessarily related to one of my configurations? In that case, it would be helpful to know where the problem is occurring.
Thank you.
Home Assistant 2023.8.4
Supervisor 2023.08.3
Operating System 10.5
interface utilisateur : 20230802.1 - latest
