Hello everyone,
I hope I’m at the right place to ask my questions. Sorry I had to remove almost all of my links, I can post only 2 links. Ok well first I’m a total newcomer, I’ve never used Home assistant but I’ve read A LOT and seen A LOT about it. First, I have fully read getting started
I have so many questions that I’m not even sure to ask them in the right order or even correctly.
I want to install a raspberry PI with the official touchscreen on the wall and install home assistant on this system. Ok now I need to understand everything that is needed for this setup and I struggle to understand everything.
Using the PI as home assistant with the GUI
First, in the getting started it seems that I need to access the home assistant configuration on the network but will I be able to use the screen connected to the pi itself to configure home assistant (reminder : Home assistant is installed on the RPI and the touchscreen will also be connected to this same RPI) ?
Within a few minutes you will be able to reach Home Assistant on homeassistant.local:8123. If you are running an older Windows version or have a stricter network configuration, you might need to access Home Assistant at homeassistant:8123 or
http://X.X.X.X:8123
(replace X.X.X.X with your Raspberry Pi’s IP address).
Is it possible to install home assistant on the PI and that the same PI will be the GUI (I’d like to avoid buying another PI or a tablet to have access to the GUI). This question is not very clear but when reading what I have quoted above I’m afraid I need to access the configuration over the network with ANOTHER computer/tablet/RPI. I don’t even know what is displayed on the RPI output after installing Home assistant on the RPI itself. People who have installed servers knows probably what I am talking about, connect a server to a screen and nothing very user friendly will be displayed.
Protocols
From what I’ve read there’s a f***ing bunch of protocols that are used I can’t even list them that would be stupid…
- Zigbee
- Zwave
- MQTT (I still don’t really understand what MQTT is but I will find more information myself don’t bother with that)
- proprietary something
- proprietary something else
This means that for each protocol I need what is usually called a “gateway” (correct ?). Which means that in order to be compliant with a lot of protocols I need as many gateways as protocols (or a gateway that is multi-protocols of course). Some equipments are directly wifi but let’s forget those for the moment.
If this is true : What is the most useful gateway (by useful I mean not overpriced but still compatible with as many protocols as possible (and compatible with RPI of course), I don’t want to buy something around 200 euros for compatibility).
oh and ESP stuff do not need a gateway ?
This integration allows ESPHome devices to connect directly to Home Assistant with the native ESPHome API
Gateway connection
Then
- I need to connect this gateway to the usb port of the raspberry pi correct (in case of a USB gateway) ?
- It auto-configure itself to communicate with home assistant installed on the RPI ?
- I need to download the “integration” to use it for example for zigbee : /integrations/zha/ (sorry can’t link) ?
- Then I need to learn how to configure the equipment itself in the GUI
I’ve read here that
Home Assistant will show any devices that it has discovered on your network
You might notice a “discovered” section. This section contains integrations that were found on your network and can easily be added with a few clicks
So maybe I just need to connect the gateway to the RPI and then everything is automated, home assistant sees every object that is connected to the gateway as long as it is compatible (not always according to what I’ve quoted).
Sorry for all those questions but I have not found explicitly answers to those questions
Oh one more bonus question for me. I have seen that some gateways can be installed directly on the fuse box someone has already tried ? It seems way cleaner than having multiple usb gateways connected to the RPI ? Oh forget that you of course still need to connect the gateway to the RPI and because I want the screen in the middle of the living room this is impossible.
