Since I can say to ASSIST something like “open cover to fifty percent”, THERE must be already an automatic conversion from a spoken number into an integer or a float.
In my case I defined a Sentence triggered automation which should take an intent and a number like “set X to thirtyfive seconds”, having X to be a number_sensor to be set to 35 (not “thirtyfife”…) .
How should I define the sentence to catch that number? Like e.g. “set X to {seconds} seconds”
How can I ensure that X be set to the integer or float representation of the spoken number (here seconds)?
Thank you so much in advance for any hints.
PS: The followint does not function and does not even tell why not:
actions:
entity_id: input_number.X
value: “{{ trigger.event.data.variables.seconds | int }}”
The Assist (executing this) says just “Done” Which must be a kind of catch-all … and I suppose something wrong happens…
Not too clear what you’re trying to do, but we need to see the whole automation, and you’ll need to post it as preformatted text (</>) in the toolbar.
However, if you use a custom sentence and an intent script you can define the number slot as a range and it will always be passed to the intent as a number, whatever the voice assistant “hears”.
language: "en"
intents:
CustomAlarmclockSet:
- sentences:
- "set ( the | an ) alarm for {hour} {minute}"
lists:
hour:
range:
to: 23
minute:
range:
to: 59
alias: ASSIST RESPONSE Set Light Time Kitchen
triggers:
- trigger: conversation
command: Set light time of Kitchen to {seconds} seconds
actions:
- target:
entity_id: input_number.rip_cucina_inching_off_secs
value: "{{ trigger.event.data.variables.seconds | int }}"
action: input_number.set_value
- set_conversation_response: >-
Light time of kitchen set to {{
trigger.event.data.variables.seconds }} seconds
mode: single
So basically I wish to set the spoken value (as number) in
You should do automation (custom sentences) in YAML, as shown above. This is because lists for ranges only work there (the unicode-rbnf library is used).
But then I still do not know where to change…
OK, event does not exists, so what should be the expression there?
How should I change my code?
It should not be too difficult… But since I do not know the implementation, I permit myself to ask here…
This is what I have understood (from your kind suggestions so far) to do:
NB: list cannot be entered in the yaml description of an automatioin.
triggers:
actions:
- target:
value: "{{ seconds | int }}"
Light time of kitchen set to {{ seconds }} seconds
mode: single
But this won’t work. Any sugg what I shoud change here please?
As shown in the docs linked by mchk and myself, the property of the trigger variable is called slots.
triggers:
actions:
- target:
value: "{{ trigger.slots.seconds | int }}"
Light time of kitchen set to {{ trigger.slots.seconds }} seconds
mode: single
Doing it this way will usually work, but it is possible that seconds gets returned as a string value like “thirteen” which will cause the action to fail. If you go with this, it would be prudent to add a default to the int filter to avoid those complete failures. Or you could use a kind-of silly template to convert them.
Using a custom intent like Jackjourneyman showed above is the more sure-fire method.
Without the set action (which indeed uses the text representation of a number instead of the number as integer), now the automation “reponds” with the right argument (seconds) as a text.
Now: I have a web service which translates a number as text into a json obj containing the corresponding number representation (because I need the number, not the speaking part).
It is in italian (because I am de-facto working on an italian speaking version)
