roippi
(Ben Roberts)
March 7, 2025, 11:05pm
1
Hi, turning a developer topic post into a FR, this is the original thread: Mount hosts /proc & /sys into add on container
Basically, for certain advanced container monitoring abilities , appliances such as datadog/agent require mounting of /proc and /sys/fs/cgroup into the agent container. While mounting docker.sock is covered via docker_api:true, neither /proc nor /sys/** is currently allowed to be mounted in devices: via an addon. (gpio and filetree get a couple of special hardcoded exceptions)
I understand allowing an addon to do this would, at minimum, require turning off all relevant security flags.
I am happy to contribute a PR if this is acceptable.
roippi
(Ben Roberts)
March 7, 2025, 11:17pm
2
Relevant DD docs showing the docker mounts: Docker Agent for Docker, containerd, and Podman
CLI equivalent: docker run -d --cgroupns host --pid host --name dd-agent -v /var/run/docker.sock:/var/run/docker.sock:ro -v /proc/:/host/proc/:ro -v /sys/fs/cgroup/:/host/sys/fs/cgroup:ro -e DD_SITE=<DATADOG_SITE> -e DD_API_KEY=<DATADOG_API_KEY> gcr.io/datadoghq/agent:7
felipecrs
(Felipe Santos)
March 26, 2025, 11:43pm
3
I have the exact same need for Netdata.
@roippi I was able to work around it by using nsenter, which is extremely hacky and dangerous.
mv -fv /homeassistant/netdata /config/
fi
# This is a trick to mount host directories and files inside the container,
# given HA add-ons cannot specify bind mounts.
if ! mountpoint --quiet /host/etc/os-release; then
set_container_id
set_container_root_on_host
# Mount /proc from host to /host/proc as readonly with nsenter
mkdir -p /host/proc
nsenter --target 1 --mount -- \
mount --bind --read-only /proc "${container_root_on_host}/host/proc"
# Same for /sys and /sys/fs/cgroup
mkdir -p /host/sys
mount --bind --read-only /sys "${container_root_on_host}/host/sys"
mount --bind --read-only /sys/fs/cgroup "${container_root_on_host}/host/sys/fs/cgroup"
It would be a lot simpler and even safer if there was an option to add arbitrary mounts in add-on’s config.yaml.
felipecrs
(Felipe Santos)
March 26, 2025, 11:50pm
4
A very important note is that only read-only access to these directories are required. This should greatly reduce the risk.
