About editing automation triggers or actions
Maybe I’m being really dumb, but is there really no way to use the visual UI to change automation actions? I mean other than to just add a new one instead.
Example: doing an automation with various different 'Turn on" and 'Turn off" things…it would be so easy do edit by adding one, then duplicating and changing the “on” to “off” or vice versa. Now it does not seem to be possible with the new automation UI (previously it was easy). Always need to create a new one from scratch if I want to use another action on the same entity.
Or, when you notice you picked the wrong one, then just edit it…instead of deleting and adding a new one.
I know I can still do it in YAML, of course.
