About Remote Assistant and BLE Monitor
Hello, I’d like to increase the range of my Home Assistant Instance (Home Assistant Core on a Rapsberry Pi 4) with BLE Monitor because I regularly loose data points from my most distant sensors (Xiaomi LYWSD03MMC sensors and Flower Care).
I’ve seen on the documentation of ble_monitor that it’s either possible to use an ESP32 as a bluetooth gateway, or to use another Home Assistant instance with remote_homeassistant.
For the later, before going trough the trouble of installing another Raspberry Pi and Home Assistant, I was wondering if I’ll need to reconfigure my sensors to be polled by the remote instance, or if it will forward BLE advertisements raw to the main instance. I couldn’t find a clear answer.
Thanks.
