I’m using xiaomi_lywsd03mmc and ESP32 to control my underfloor heating.
The climate module in ESPHome together with the xiaomi bluetooth temperature devices seems to be making a fine autonomous system that can operate even if HA is not accessible.
There’s just a small issue… If one of the underfloorheating valves open and the BT device for some reason goes offline or is just inaccessible then the climate controller will keep heating .
I wonder if there is a way of accessing the bluetooth signal strength directly inside an ESP32?
Or if its possible to check last time the ESP heard from a bluetooth device? - remember we are talking directly in ESP to keep the system autonomous .
hi @danielw
(I’ll remove some code to keep it simple)
Here is one of my relays:
- platform: gpio
pin: 13
inverted: True
restore_mode: RESTORE_DEFAULT_OFF
on_turn_on:
- logger.log: "Switch Turned On: Stue"
on_turn_off:
- logger.log: "Switch Turned Off: Stue"
Here’s the climate controller that uses the relay:
climate:
- platform: thermostat
name: "Stue Termostat"
sensor: stue_temp
default_target_temperature_low: 20 °C
heat_action:
- switch.turn_on: stue_heat
idle_action:
- switch.turn_off: stue_heat
visual:
min_temperature: 16 °C
max_temperature: 22 °C
temperature_step: 1 °C
I’ve actually managed to get a rssi working on the BT sensor:
(This code doesnt work yet!)
I would like to know if the rssi signal is … well anything else than a number that is acceptable.
I can see that the esp console just output “nan” if the sensor is not accessable, but this doesnt work directly in lambda if statement.
- platform: ble_rssi
mac_address: A4:C1:38:5E:02:EB
name: "sensor signal strength"
filters:
- lambda: if (x == "nan") return x; else return {}; #Not working...
on_value:
then:
- logger.log: "No contact to sensor!"
OK, nice. So you got it working.
You can check for nan (Not a Number) with the isnan function like so:
filters:
- lambda: if ( isnan(x) ) return -1; else return x;
on_value:
then:
thanks @danielw , I’ll implement it when I get a esp with a little more flash - I think I have pushed it to the limit right now
