Access Config folder over internet (externally) on Android Phone
What is the best way to access my Config folder on Android over the internet when away from home. If using a PC I would use the VS Code add-on but this is not useable on mobile.
I have homeassistant cloud and duckdns set up and have forwarded the external port of 22 to the internal IP address of my pi.
I have the SSH and Web Terminal add-on installed and SFTP set to true but I can’t get an SFTP app ( Code Editor) to connect.
I know it’s possible because I used to do it with the Droid Edit app but I seem to do it now.
Official addon file editor
Fairly lightweight. Has ingress.
Thanks but I still don’t think coding within the HA frontend is a good experience, I was hoping for a stand alone app method of coding yaml files
Does the community ssh and terminal addon let you access it?
GitHub - hassio-addons/addon-ssh: SSH & Web Terminal - Home Assistant Community Add-ons.
I try not to code at all on my small Android screen…
I think it should do but I can’t get it to work
