Hello together,
I would not consider me a total newbie with coding and home automation, but I now hit a roadblock and can not find any hint how to resolve it online:
Running a Raspberry Pi 4B with the standard HAOS installation. Config files are stored in the folder /homeassistant and native local backups are created in the folder /backup
Triggering a shell command I was able to create a file in the /homeassistant folder and also transfer this file externally to another remote FTP server.
However I can not get access from this shell command to anything in the /backup folder - neither create the same file in this location nor transfer files from that folder locally or remotely.
Can somebody point me please into the right direction, how to access the /backup folder from within any automation? I assume it has to do with HA running within a container? And potentially thus with a user not being able to access the other folder(s)?
Thanks for any explanation or hints how to work my way around ![]()
