I’ve successfully added the Tailscale app and configured it. The problem I have is that if I want to reach it via my dns (via zoraxy proxy) address, home assistant doesn’t allow the access: 400 - Bad Request Access via the Tailscale DNS works fine. I have the following in configuration.yaml to allow access via my pfsense (running tailscale):
The proxy server has the correct Tailscale IP/DNS set. And I can reach home assistant via this dns forward. BUT home assistant blocks the access because it’s a proxy.
Therefore there is this entry in configuration.yaml, which works if I go via pfsense/Tailscale BUT doesn’t if Tailscale is directly installed on home assistant.
