I am currently in a different location. I did a similar test.
AP configuration:
#!/bin/bash
CONN_NAME="RPIHotspot"
AP_SSID="RPI"
AP_PASS="RPItestRPI"
AP_IFACE="wlan1"
nmcli con delete $CONN_NAME
nmcli con add type wifi ifname $AP_IFACE mode ap con-name $CONN_NAME ssid $AP_SSID
nmcli con modify $CONN_NAME wifi.band bg
nmcli con modify $CONN_NAME autoconnect yes
nmcli con modify $CONN_NAME wifi-sec.key-mgmt wpa-psk
nmcli con modify $CONN_NAME wifi-sec.psk $AP_PASS
nmcli con modify $CONN_NAME wifi-sec.pairwise ccmp
nmcli con modify $CONN_NAME wifi-sec.proto rsn
nmcli con modify $CONN_NAME ipv4.method shared
nmcli con modify $CONN_NAME ipv6.method disabled
# Disable: 2 - NM actively disables power save
# Enable: 3 - NM actively enables power save
# Ignore: 1 - NM ignores power save settings
# Default: 0 - NM uses the globally configured value (in NM)
nmcli con modify $CONN_NAME 802-11-wireless.powersave 3
My yaml with bluetooth:
substitutions:
external_components_source: github://syssi/esphome-jk-bms@main
mac_address: C8:47:80:28:B7:97
# Please use "JK02_24S" if you own a old JK-BMS < hardware version 11.0 (hardware version >= 6.0 and < 11.0)
# Please use "JK02_32S" if you own a new JK-BMS >= hardware version 11.0 (f.e. JK-B2A8S20P hw 11.XW, sw 11.26)
# Please use "JK04" if you have some old JK-BMS <= hardware version 3.0 (f.e. JK-B2A16S hw 3.0, sw. 3.3.0)
protocol_version: JK02_32S
esphome:
friendly_name: testwifi
esp32:
board: esp32dev
framework:
type: arduino
external_components:
- source: ${external_components_source}
refresh: 0s
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "ARJ/PzF+AnvBnFeJrHyNc8sRaX9Fs6vFV0uhUWAtBZE="
ota:
- platform: esphome
password: "e42ddf56f574ec92d04971e536d5e705"
wifi:
ssid: RPI
password: RPItestRPI
ap:
ssid: "Testwifi Fallback Hotspot"
password: "0WNYzOmX5Qec"
captive_portal:
ble_client:
- mac_address: ${mac_address}
jk_bms_ble:
- ble_client_id: client0
protocol_version: ${protocol_version}
throttle: 5s
binary_sensor:
- platform: jk_bms_ble
balancing:
name: "${name} balancing"
charging:
name: "${name} charging"
discharging:
name: "${name} discharging"
online_status:
name: "${name} online status"
jk_bms_ble_id: bms0
total_voltage:
name: "${name} total voltage"
current:
power:
charging_power:
name: "${name} charging power"
discharging_power:
name: "${name} discharging power"
ping test from rpi:
ping -c 100 10.42.0.122
— 10.42.0.122 ping statistics —
100 packets transmitted, 59 received, +36 errors, 41% packet loss, time 123962ms
rtt min/avg/max/mdev = 12.165/1149.313/14481.120/3475.946 ms, pipe 6
simple yaml:
esphome:
friendly_name: testwifi2
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
key: "W0KngbNsp650RxrRQSfSYs8Nt8+NtP5EX48MLkBC8gE="
ota:
- platform: esphome
password: "556977db5c689a06586de78ab3be141c"
wifi:
ssid: RPI
ap:
ssid: "Testwifi2 Fallback Hotspot"
password: "5FKY9bFWypVB"
captive_portal:
ping test result:
100 packets transmitted, 71 received, +14 errors, 29% packet loss, time 133046ms
rtt min/avg/max/mdev = 12.303/782.654/16126.911/3020.881 ms, pipe 9
when add power_save_mode: NONE
ping
100 packets transmitted, 100 received, 0% packet loss, time 99167ms
rtt min/avg/max/mdev = 3.388/5.614/21.047/2.704 ms
Response times are much faster and there are no packet losses
It’s probably something with the new RPI OS (bookwork) and NetworkManager. When I configured the AP on the old RPI OS (buster) using dnsmasq and hostapd I had no packet losses.
