Hi All,
I tried to search everywhere for this, but missing to find any info around how to expose the docker socker and other items to my custom Datadog v5 agent. I really like the datadog agent monitoring around docker and system performance and figured to write a plugin that exposes this info, perhaps including pulling of the logs to datadog.
My issue seems to be, knowing what to use on both a privilege side and a config.json side. I see in the addons repo there is a specific component for providing privileges to another addon, but cant see this in the hassio vagrant image to install it. as well as docs on what to configure.
I have tried to put the configs under maps and under devices (which fails).
Would really appreciate any help. Config below.
config.json
"name": "Datadog v5",
"version": "1",
"slug": "datadog_v5",
"description": "Enable datadog monitoring for your cluster with docker support",
"startup": "system",
"boot": "auto",
"ports": {
"8125/udp": 8125
"options": {
"api_key": ""
"schema": {
"api_key": "str"
"hassio_api": false,
"homeassistant_api": false,
"host_network": true,
"hassio_role": "manager",
"apparmor": false,
"privileged": [
"SYS_ADMIN",
"SYS_RAWIO"
"maps": [
"/var/run/docker.sock:/var/run/docker.sock:ro",
"/proc/:/host/proc/:ro",
"/sys/fs/cgroup/:/host/sys/fs/cgroup:ro"
"docker_api": true,
"host_ipc": true,
"host_dbus": true,
"host_pid": true,
"full_access": true,
"environment": {
"LOG_FORMAT": "{LEVEL}: {MESSAGE}",
"SUPERVISOR_VERSION": ">=0.77.0"
