Access to some device without login
Is it possible to have some device available without login and all the others after the login?
I want to use Home Assistant in my office, but with the automation system (now we use Domoticz) we open the gates too and if someone rings at the gate and I got logged out of HA (for whatever reason) and I need to open the page, login and only then I’ll be able to open the gate…well, it’s a bit too much to ask to my colleagues.
Thanks!
Without doing something custom, this isn’t possible. That being said, I’ve never been logged out of HA on any device unless I manually do so.
Login is stored in a cookie, if for some reason the cookie is deleted, you are logged out.
It is all or nothing, but you can use ‘trusted networks’ to bypass login
That’s unfortunate, but thanks!
What about using a wireless remote instead of app/webUI?
I thought about that when I first installed everything, but I couldn’t find a good WiFi button with a long lasting battery and I had no ZigBee coverage. Do you have any good ones to suggest?
P.s. How is it that I don’t receive emails when someone reply to one of my post?
What is it that controls the gates?
Regarding mails: have you checked your profile settings here and the unwanted mails folder of that e-mail address?
A ModBus relay board that I control with Node Red.
I did. I’ll try to set this option
Send me an email when someone quotes me, replies to my post, mentions my @username, or invites me to a topic
with always instead of only when away (even if you replied me 8h ago and the PC was off.
Can this be an option: GitHub - LAB02-Research/HASS.Agent: Windows-based client for Home Assistant. Provides notifications, quick actions, commands, sensors and more.
Did you sign out from the forum after making these settings?
If still an issue, you can raise the issue by contacting an admin/moderator…
That could be a solution, thanks!
I didn’t. I just did, let’s see if it works now.
Thanks!
