Access to Zigbee2MQTT base topic or integration context in automations
Title: Access to Zigbee2MQTT base topic or integration context in automations
Body:
Hi everyone! :wave:
I’d like to request a feature related to multi-instance Zigbee2MQTT setups in Home Assistant.
:loudspeaker: The problem
When running multiple Zigbee2MQTT instances (e.g., in separate buildings, zones, or coordinators), devices may have overlapping or similar entity names like:
binary_sensor.kitchen_water_leak
binary_sensor.kitchen_water_leak_2
But these entities belong to different Zigbee2MQTT integrations (with different base MQTT topics), and there’s currently no way in automations to detect or access which base topic a device is tied to.
This makes centralized automations extremely difficult to manage without hardcoding or duplicating logic.
:x: Limitations today
  • There is no way to get the base MQTT topic of a Zigbee2MQTT entity in automations.
  • Accessing the area in templates is technically possible, but only if the entity has been manually assigned to an area — and this doesn’t reflect the actual Zigbee2MQTT instance or topic.
  • There’s no built-in device.zigbee2mqtt_topic, zigbee_instance, or similar metadata.
:white_check_mark: What would help
Allow templates in automations to access:
  • The base MQTT topic an entity is linked to (e.g. zigbee2mqtt_home1, zigbee2mqtt_home2)
  • Or an explicit Zigbee2MQTT instance ID
This metadata could be available via device_attr(), state_attr(), or similar.
:arrows_counterclockwise: Workarounds today
Currently, we are forced to:
  • Encode the Zigbee2MQTT topic in the entity name manually
  • Duplicate automations for each instance
  • Use naming conventions or assign custom attributes outside of HA
None of these scale well for dynamic or large deployments.
:sparkles: Suggested API or template additions
Something like this in templates would be ideal:
{{ device_attr(trigger.entity_id, 'zigbee2mqtt_topic') }}
This would make multi-hub setups much more powerful and allow truly reusable, scalable automations.
Thanks for considering!
Adding an attribute to Zigbee2mqtt entities would be more a feature request for Zigbee2mqtt.
First, vote for your own request.
Why not just use trigger ids?
If you use mqtt triggers, the base mqtt topic is in the trigger.
