Accessing external temperature sensor in tuya thermostat
I am giving my first steps in HA (and loving it so far).
I am trying to use some wall thermostats to control my hot water based underfloor heating. Those thermostats have a room temperature sensor (located inside the thermostat) and an additional external sensor (a wired NTC probe) that I simply plug one side of the cable to the thermostats and the NTC end I insert in a copper pipe introduced in the floor to measure the floor temperature.
Using Smart life App I am able to see both temperatures by selecting the sensor source (internal ou external).
I am using these thermostats in HA using Tuya integration (probably in the future I will use LocalTuya) and I can only see one temperature entity (one temperature).
I realize that the temperature read by the HA is the temperature shown by the thermostat (the internal sensor reading or the external sensor reading depending on which one is selected as temperature sensor source in the Smart Life).
However I cannot figure out how to read both sensors or a way to change the sensor source from HA.
As newbie in HA I would appreciate any help. Thank you
