I am trying to setup an Acer UT222Q Touch monitor on a Raspberry Pi 5 running the latest version of HAOS as of Jan 2026, and HAOS-Kisok. While the display is working as intended, the touch functionality of said display is not. Has anyone had experience successfully getting a touchscreen monitor running correctly a setup similar to this?
I figured out my problem. I hadn’t connected the USB cable that came with the monitor to my Raspberry Pi. Once i did that and then REBOOTED, everything worked.
