Action not working but error msg impires it should be
What is wrong with this action? I only ask because the error implies it is all ok.
    - delay: >
        value_template:
          {% if is_state('input_boolean.holiday_settings_lights', 'on') %}
            00:{{ "{:02d}".format(range(1, 2)|random|int) }}:{{ "{:02d}".format(range(0, 30)|random|int) }}
          {% endif %}
    - service: homeassistant.turn_on
      entity_id: switch.hall_light
Log Details (ERROR)
Thu Apr 12 2018 15:13:07 GMT+0100 (GMT Summer Time)
Error rendering 'Hall light on at dusk' delay template: offset value_template:
00:01:29 should be format 'HH:MM' or 'HH:MM:SS'
from the error message it would appear you’re missing a single quote around your delay:
            '00:{{ "{:02d}".format(range(1, 2)|random|int) }}:{{ "{:02d}".format(range(0, 30)|random|int) }}'
          {% endif %}
Yeah, I tried that too…
(The error looks even more strange!)
Log Details (ERROR)
Thu Apr 12 2018 16:11:06 GMT+0100 (GMT Summer Time)
    '00:01:10' should be format 'HH:MM' or 'HH:MM:SS'
It doesn’t look like there’s as a value / value_template for a delay.
Have you tried:
    - delay: >
        '{% if is_state('input_boolean.holiday_settings_lights', 'on') %}
          {% endif %}'
Brilliant! Thank you very much, that worked (but I removed the single quotes you have around the entire statement).
Oh dear, I spoke too soon. For some reason it doesn’t work after all.
Edit: I think it needed an ‘else’. (Not sure if 00:00:00 would have been valid)
  00:{{ "{:02d}".format(range(1, 14)|random|int) }}:{{ "{:02d}".format(range(0, 59)|random|int) }}
{% else %}
  00:00:01
{% endif %}
    # delay a random amount of time between 1 and 15 minutes if on holiday
    - delay: >
        {% endif %}
      entity_id: switch.dining_room_light
Slightly different error.
Log Details (ERROR)
Thu Apr 12 2018 21:15:30 GMT+0100 (GMT Summer Time)
Error rendering 'Dining room light on at dusk if someone is home' delay template: offset should be format 'HH:MM' or 'HH:MM:SS'
yes that makes sense, a delay needs a value, so you would need the else statement…
