Actionable notification to open/close cover of an open window
hey guys,
i´m trying to make an automation that´s called by an actionable notification to open or close a cover of a window that is open. however i can´t get it working. maybe someone has an idea or even a better way to do it.
the notification:
action: notify.mobile_app_iphone_david
  message: Fenster erkannt! Was möchtest du tun?
    actions:
      - action: open
        title: open
      - action: close
        title: close
since i have 9 windows i think using a variable like this makes it more easy:
      covers:
        window_hallway_contact: cover.hallway
        window_bedroom_1_contact: cover.bedroom_1
        window_bedroom_2_contact: cover.bedroom_2
        window_office_1_contact: cover.office_1
        window_office_2_contact: cover.office_2
        window_livingroom_1_contact: cover.livingroom_1
        window_livingroom_2_contact: cover.livingroom_2
        window_livingroom_3_contact: cover.livingroom_3
        door_balcony_contact: cover.balcony
this is the automation i have right now, that´s not working:
alias: "Fensterstatus Rolladensteuerung"
  - platform: event
    event_type: mobile_app_notification_action
  - variables:
      action: "{{ trigger.event.data.action }}"
      covers:
  - repeat:
      for_each: "{{ covers.keys() | select('is_state', 'on') | list }}"
      sequence:
        - service: "cover.{{ 'open_cover' if action == 'open' else 'close_cover' }}"
            entity_id: "{{ covers[repeat.item] }}"
mode: parallel
The keys are not entity IDs… so | select('is_state', 'on') doesn’t know what to do with them.
Also, be aware that your trigger is not very specific, so this automation will run every time you activate any notification action. That is one of the reasons why the examples in the companion app docs use Wait for Trigger actions instead of separate automations for actionable notifications.
that´s something chatgpt gave me since i couldn´t figure it out :smiley:
i know that it runs everytime, it was just to figure it out. however i didn´t manage…
right now i think it would be easier to make 2 scripts: one that would open the cover and one that would close it. and call the scripts by the action “open” or “close”. however i also can´t get one of the scripts working :smiley:
came up with this automation, guess it´s not the prettiest way to do it, but it works.
so if someone knows a better way (getting rid of all the if/then, maybe using variables) would be nice if he could post it.
alias: Fenster Rolladensteuerung via Mobile Notification
triggers:
  - trigger: event
    event_data:
      action: open
  - trigger: event
    event_data:
      action: close
actions:
  - choose:
      - conditions:
          - condition: trigger
            id:
              - open
        sequence:
          - action: notify.mobile_app_iphone_david
            metadata: {}
              message: open
          - if:
              - condition: state
                entity_id: binary_sensor.window_hallway_contact
                state: "on"
            then:
              - action: cover.set_cover_position
                metadata: {}
                  position: 100
                  entity_id: cover.hallway
          - if:
              - condition: state
                entity_id: binary_sensor.window_bedroom_1_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.bedroom_1
            enabled: false
          - if:
              - condition: state
                entity_id: binary_sensor.window_bedroom_2_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.bedroom_2
          - if:
              - condition: state
                entity_id: binary_sensor.window_office_1_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.office_1
          - if:
              - condition: state
                entity_id: binary_sensor.window_office_2_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.office_2
          - if:
              - condition: state
                entity_id: binary_sensor.window_livingroom_1_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.livingroom_1
          - if:
              - condition: state
                entity_id: binary_sensor.window_livingroom_2_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.livingroom_2
          - if:
              - condition: state
                entity_id: binary_sensor.window_livingroom_3_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.livingroom_3
          - if:
              - condition: state
                entity_id: binary_sensor.door_balcony_contact
                state: "on"
            then:
                metadata: {}
                  position: 100
                  entity_id: cover.balcony
      - conditions:
            id:
              - close
        sequence:
            metadata: {}
              message: close
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
            enabled: false
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
          - if:
              - condition: state
                state: "on"
            then:
                metadata: {}
                  position: 20
mode: parallel
Your original script will work if you change the keys to the actual entity IDs… so instead of window_hallway_contact: it would be binary_sensor.window_hallway_contact:
Alternatively, you could append the the binary_sensor. string to each key in the for_each template, but that would require a loop and the use of a namespace.
In either case and for long-term stability, I would suggest you change the action titles in the calling automation to something more unique like “open_alles_fenster_rolladen”. Make sure to update the trigger(s) and the service template in the repeat to match whatever you change it to.
thanks alot, couldn´t have figured that out on my own!
here is the working code:
description: ""
triggers:
  - trigger: event
    event_data:
      action: open
  - trigger: event
    event_data:
      action: close
actions:
  - variables:
      covers:
        binary_sensor.window_hallway_contact: cover.hallway
        binary_sensor.window_bedroom_1_contact: cover.bedroom_1
        binary_sensor.window_bedroom_2_contact: cover.bedroom_2
        binary_sensor.window_office_1_contact: cover.office_1
        binary_sensor.window_office_2_contact: cover.office_2
        binary_sensor.window_livingroom_1_contact: cover.livingroom_1
        binary_sensor.window_livingroom_2_contact: cover.livingroom_2
        binary_sensor.window_livingroom_3_contact: cover.livingroom_3
        binary_sensor.door_balcony_contact: cover.balcony
  - choose:
      - conditions:
            id:
              - open
        sequence:
          - repeat:
              sequence:
                - target:
                    position: 100
      - conditions:
            id:
              - close
        sequence:
          - repeat:
              sequence:
                - target:
                    position: 20
mode: parallel
