Actionable notification with different buttons depending on trigger
I’m setting up an actionable notification. Everything works as expected, except that I want to show different action buttons depending on the trigger - Without having to set up a notification for each case. (The case here is: If phase 1 current is too high, only show buttons for switching to phase 2 and 3. If phase 2 is too high, only show buttons for 1+3. And so on.
Currently the action looks like this. It shows all three buttons regardless:
action: notify.my_device
  message: The charger is using too much power. How do you want to handle it?
    push:
      sound:
        critical: 1
        volume: 1
    actions:
      - action: "{{ action_pause }}"
        title: Pause
      - action: "{{ action_switch_to_l1 }}"
        title: Change to phase 1 ({{ states('sensor.current_l1') | round(1) }} A)
      - action: "{{ action_switch_to_l2 }}"
        title: Change to phase 2 ({{ states('sensor.current_l2') | round(1) }} A)
      - action: "{{ action_switch_to_l3 }}"
        title: Change to phase 3 ({{ states('sensor.current_l3') | round(1) }} A)
Based on the trigger id I want to do something like this (has a bit of pseudo code in it since I don’t know the syntax)
    push:
      sound:
        critical: 1
        volume: 1
    actions:
        title: Pause
      if (trigger != 'l1')
      if (trigger != 'l2')
      if (trigger != 'l3')
Is it possible? I know that I can create three different notification actions, but I want to avoid that.
If the actions attribute itself supports templates, then the solution is kind of obvious – build a template that returns a dict containing the desired actions. If it does not, then I’d say it is not possible.
actions: >-
  {% if whatever %}
    {{ {'action': action_pause, 'title': 'Pause'} }}
  {% else %}
  {% endif %}
Ok, I Will test if that works. That was really my question, if this was templateable :).
