thanks for this card. Unfortunately the issue seems to persistā¦
When setting as follows, the action works when testing inside the visual editor, but after pressing save the ādata: ā¦ā field isnāt saved, only the tap action, action, and service fields.
Thanks for the head-up. The data was saved to the yaml though, so it should have worked, but I now fixed the service data field. It will properly save your configuration. Please download v1.5.5 and let me know if it is fixed.
I tried to use your card yesterday, but it looks like it is not possible to make an action dynamic.
I wanted to use the card for my update window, so I needed it to be able,through templates, to set the different actions I could do for each object in my window, like open a webpage, do an action/service call and so on.
Is it possible to get it to accept templates for at least the action keys?
Currently it is only possible to trigger a single action. I would recommend using a script or automation to trigger multiple actions with a single gesture.
