Actron Air Conditioner add-on
I recently got a new Actron Advance system installed but spec’d it with their ICUNO-MOD modbus card and the L-series controllers rather than a Neo controller. It was surprisingly easy to get working in home assistant via the modbus climate integration and using a cheap modbus TCP to RTU adapter. If anyone is interested here is my yaml config for it. This option gives full local control direct from HA without any cloud stuff.
modbus:
  - type: tcp
    host: 192.168.222.243
    port: 8887
    climates:
      - name: Actron Advance
        address: 851
        precision: 1
        scale: 0.1
        target_temp_register: 102
        max_temp: 30
        min_temp: 16
        temp_step: 0.5
        temperature_unit: C
        hvac_onoff_register: 1
        hvac_mode_register:
          address: 101
          values:
            #off: 0
            auto: 3
            cool: 2
            heat: 1
            fan_only: 4
        slave: 1
    switches:
      - name: Actron Zone1
        slave: 1
        address: 5001
        verify:
            address: 5001
            input_type: holding
      - name: Actron Zone2
        slave: 1
        address: 5002
        verify:
            address: 5002
            input_type: holding
      - name: Actron Zone3
        slave: 1
        address: 5003
        verify:
            address: 5003
            input_type: holding
      - name: Actron Zone4
        slave: 1
        address: 5004
        verify:
            address: 5004
            input_type: holding
      - name: Actron Zone5
        slave: 1
        address: 5005
        verify:
            address: 5005
            input_type: holding
      - name: Actron Zone6
        slave: 1
        address: 5006
        verify:
            address: 5006
            input_type: holding
      - name: Actron Zone7
        slave: 1
        address: 5007
        verify:
            address: 5007
            input_type: holding
    sensors:
      - name: Actron WC1
        unit_of_measurement: °C
        precision: 1
        scale: 0.1
        slave: 1
        address: 6001
      - name: Actron WC2
        precision: 1
        scale: 0.1
        slave: 1
        address: 6002
      - name: Actron WC3
        precision: 1
        scale: 0.1
        slave: 1
        address: 6003
      - name: Actron Outside
        precision: 1
        scale: 0.1
        slave: 1
        address: 852
      - name: Actron Indoor
        precision: 1
        scale: 0.1
        slave: 1
        address: 851
