This integration bridges ActronAir NEO systems via their cloud API and exposes key climate control features directly in Home Assistant. It’s designed for simplicity and quick setup — no need for extra hardware or MQTT.
Features
Supports multiple zones
Control modes (cool, heat, auto, fan-only, dry)
Zone temperature and setpoint control
Fan speed control
Real-time status updates
Setup
Just follow the instructions in the GitHub README. Add it via HACS (or manually), restart, and configure through the integrations UI.
I have been using this for six months now and it hasn’t had any problems that have impacted its use in my house.
The developer has been really responsive and helpful when I have raised issues on github.
On a side note, we don’t get as much support for Australian-only products, so if you’re using this, consider giving back in any way you can afford. This might involve raising issues when things aren’t working properly, helping with debugging, or providing monetary support through the link on their GitHub. To clarify, I have no affiliation with the developer and don’t know who they are. I simply believe in giving back in any way you can.
What’s the responsiveness of the HACS integration like? I’ve found there’s a bit of lag with the add-on, so I’d be keen to explore an alternative option.
@slace Feel free to try it out and provide feedback. This integration doesn’t rely on MQTT like the add-on so queries to the ActronAir Neo Cloud API is direct.
Actron have now added the Zone position % to be partially opened and closed in the App, which would be idea to be able to regulate the flow of air throughout the house instead of switching the zones on/off. The control seems to be exposed (like a window blind ) gives a < ■ > or a slide cover style
neither work at this stage
This integration is really good so thanks to the creator. But is anyone finding the actron cloud extremely shit. I am finding in the last few weeks the actron neo app or cloud routinely wont respond. And I checked my Wifi and internet and they are rock solid and everything else works except Actron. I feel the cloud control is rapidly turning to shit.
Has anyone seeing issues with Neo not updating from last week? It was working fine then all of a sudden, it doesnt work. Turning off the unit doesnt take effect with the HA card however it reflects in Neo. All my automations related to AC are breaking now. Anyone seeing issues?
