Nov 13 13:48:25 debian rtl_433[3013913]: {“time” : “2025-11-13 13:48:24”, “model” : “Acurite-5n1”, “message_type” : 49, “id” : 2482, “channel” : “C”, “sequence_num” : 0, “battery_ok” : 1, “wind_avg_km_h” : 0.000, “wind_dir_deg” : 315.000, “rain_mm” : 0.254, “mic” : “CHECKSUM”}
Nov 13 13:48:43 debian rtl_433[3013913]: {“time” : “2025-11-13 13:48:43”, “model” : “Acurite-5n1”, “message_type” : 56, “id” : 2482, “channel” : “C”, “sequence_num” : 0, “battery_ok” : 1, “wind_avg_km_h” : 0.000, “temperature_C” : 29.222, “humidity” : 41, “mic” : “CHECKSUM”}
My Acurite 5n1 is stuck broadcasting on channel C after a battery change. This occurs no matter which position the inner switch is set to, C is all I get. Home Assistant no longer detects the device as well. All my other MQTT sensors are operating as expected.
Appreciate any help, thanks!
