Adafruit ESP32-S3 Feather Setup (battery power sensors & NeoPixel)
I wanted to share a configuration for the Adafruit ESP32-S3 Feather to get others started quickly. A few things that are included:
  • Correct power activation for the IC2 bus and NeoPixel to function
  • Includes an external component for the MAX17048 Li+ Cell Fuel Gauge
  • NeoPixel light component
  • Button component (turning on the Neopixel)
  • Rainbow effect for that Adafruit feel
# Board: Adafruit Feather ESP32-S3 No PSRAM
# Definition: definitions/boards/adafruit_feather_esp32s3_nopsram/manifest.yaml
# Strapping pin warnings can be safely ignored for GPIO0 and GPIO3
esphome:
  friendly_name: "Adafruit Feather ESP32-S3"
  on_boot:
    - priority: 700
      then:
        # By default power for the IC2 and NeoPixel are turned off.
        - switch.turn_on: i2c_power # Must be turned on before the IC2 setup_priority
        - switch.turn_on: neopixel_power # Must be turned on any time before using the NeoPixel
        - delay: 500ms
    - priority: 400
      then:
        # Let's turn on the NeoPixel rainbow effect for that Adafruit feel.
        - switch.turn_on:
esp32:
  variant: ESP32S3
logger:
  level: DEBUG
  #baud_rate: 0 # This disables logs on the serial UART port.
api:
  encryption:
    key: "<your key here>"
ota:
  - platform: esphome
    encryption:
wifi:
  power_save_mode: LIGHT
  networks:
  - ssid: !secret wifi_ssid
external_components:
  # The builtin max17043 platform works with the max17048 chip, but does not
  # include the battery discharge rate sensor.
  - source: github://pr#13585 # https://github.com/esphome/esphome/pull/13585
    components: [max17048]
    refresh: 1h
i2c:
 - sda: GPIO3
   scl: GPIO4
   scan: true
   setup_priority: 600 # Initialize I2C after power is turned on.
switch:
  - platform: gpio # IC2 power supply.
    # An output could be used, but for low power modes a switch is helpful.
    pin: GPIO7
    internal: true
    restore_mode: ALWAYS_ON # let ESPHome turn it ON during setup. This is not strictly
                            # necissary, but could be used in low power modes.
  - platform: gpio # NeoPixel power supply.
    pin: GPIO21
    internal: true
    optimistic: true
    on_turn_on:
      then:
        - light.turn_on:
            brightness: 40%
            effect: "Rainbow"
    on_turn_off:
      then:
        - light.turn_off:
  - platform: wifi_signal
    update_interval: ${update_interval}
  - platform: max17048 # The builtin max17043 platform can be used instead, just
                       # remove the rate sensor if you downgrade.
    address: 0x36
    update_interval: 60s
    battery_voltage:
      entity_category: "diagnostic"
    battery_level:
    rate:
      name: "Battery Discharge Rate"
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: GPIO0
      mode:
        input: true
        pullup: true
      inverted: true
    on_click:
      then:
        - switch.toggle: toggle_neopixel
light:
  - platform: esp32_rmt_led_strip
    pin: GPIO33
    num_leds: 1
    chipset: SK6812
    channel_colors: GRB
    restore_mode: ALWAYS_OFF
    effects:
      - pulse:
          transition_length: 1000ms
          update_interval: 1000ms
          max_brightness: 80%
          min_brightness: 20%
      - addressable_lambda:
          name: "Rainbow" # https://community.home-assistant.io/t/share-your-esphome-light-effects/250294/8?u=u0398
          lambda: |-
            uint8_t led_change = 24; //(higher is more change) the difference in hue for each led down the strip
            float speed = 4; //(lower is faster) the speed the first led colour changes at (therefore affecting all)
            if (initial_run) {
              it.all() = Color(0, 0, 0);
            unsigned long time = millis() / speed;
            int repetitions = time / 1529;
            uint16_t hue = time - (1529 * repetitions);
            for (int i = 0; i < it.size(); i++) {
              if (hue < 255) {
                uint8_t green = hue;
                it[i] = Color(255, green, 0);
              } else if (hue >= 255 && hue < 510) {
                uint8_t red = hue - 255;
                it[i] = Color((255 - red), 255, 0);
              } else if (hue >= 510 && hue < 765) {
                uint8_t blue = hue - 510;
                it[i] = Color(0, 255, blue);
              } else if (hue >= 765 && hue < 1020) {
                uint8_t green = hue - 765;
                it[i] = Color(0, (255 - green), 255);
              } else if (hue >= 1020 && hue < 1275) {
                uint8_t red = hue - 1020;
                it[i] = Color(red, 0, 255);
              } else if (hue >= 1275 && hue < 1530) {
                uint8_t blue = hue - 1275;
                it[i] = Color(255, 0, (255 - blue));
              hue+=led_change;
              if (hue >= 1530) {
                hue-=1530;
