Hi there,
I’m hoping some genius out there can point me in the right direction.
I’ve FINALLY set up my HA green with Sonoff ZBdongle-E running Zigbee2mqtt and all my devices are up and running.
My goal is to get my 4 hue dimmers (v2) to behave as they should by default. Ie—
button 1: on/off
buttons 2&3: dim up/down
button 4: cycle preset scenes eg ‘concentrate, energise, read, relax, rest’
I want the hue dimmer V2 to behave as it does out of the box, but also, I want it to incorporate Adaptive Lighting. Adaptive lighting should only occur with button 1, all other buttons should override AL until button 1 is pressed again.
These seems like it should be straightforward but it’s not. I’ve investigated:
binding the controller directly to the light/group of lights in Z2M—this gets buttons 1-3 working but encounters issues with AL
Using a blueprint for controller and hook: Controller - Philips 929002398602 Hue Dimmer switch v2 | Awesome HA Blueprints
Setting the whole thing up from scratch: following, for instance, tutorials like this: https://youtu.be/L-bcabdaMxE?si=g6Arvb1A0XOB2YTL
Some combination of the above.
Can anyone suggest the best path forward? My lights seem to be receiving clashing signals and are just not behaving as I expected.
Many thanks in advance!
Brooke
