ADC to turn on/off and dim light
i’m trying to setup a esp12f module with a touch dimmer attached to A0 and a rgbw led strip attached to GPIO5, 12, 13, 14.
The Dimmer itself has an output from 0-3.3V. Simple Touch turns on or off, keeping pressed it dims up or down.
This is what my yaml looks like:
substitutions:
  device_name: "nightlight1"
esphome:
  platform: ESP8266
  board: esp12e
wifi:
  ssid: !secret wifi_ssid_2.4
  domain: .fritz.box
  use_address: nightlight1.local
#Enable logging
logger:
#Enable Home Assistant API
api:
  encryption:
    key: "key"
ota:
  - platform: esphome
    password: "password"
output:
  - platform: esp8266_pwm
    pin: GPIO5
    pin: GPIO13
    pin: GPIO14
    pin: GPIO12
    pin: GPIO4
light:
  - platform: rgbw
    red: red_gpio
    green: green_gpio
    blue: blue_gpio
    white: warm_white_gpio
  - platform: adc
    internal: True
    pin: GPIO17
    update_interval: 10ms
    filters:
      - multiply: 3.3
web_server:
  port: 80
First strange behavior: With ADC Sensor i can turn on the light using web but cannot turn it off. to turn off i have to use home assistant.
Next problem, i don’t know how to program the lambda to turn on, off and dim the light using the adc readings.
Can you please help me?
Thank you.
How? I don’t see any automation on your yaml turning on the light.
Automation could be something like this. But your update interval is smaller than Esphome loop cycle…
  - platform: adc
    internal: True
    pin: GPIO17
    on_value:
      then:
        - light.turn_on:
            brightness: !lambda "return x;"
