Is it possible to add a Matter device(or a new node) to the home assistant server(Python Matter server) without the HA app or the home assistant admin portal? like REST API, or websocket, or adding a YAML script, or some other ways?
And, is it possible to do the following activities via REST API/ websocket API even if I am using Home Assistant OS?
control the device (on/off, brightness control, etc.)
commission matter device
Create/remove Run automation.
create/remove and trigger the scene
and all the activities which is available from Home Assistant
