I currently got this:
{{state_attr('sensor.glucose_value_change', 'change' )}}
Which spits out, for example: -0.2
Thats great for negative values, but when the value is a positive one, it’ll just show as: 0.2.
I’d like to add a + symbol to that positive value, just like the “ - “ symbol on negative values.
I’m not sure which templating method to use here to look for a “ - “ and ignore, or see no symbol infront of the value, and add a “ + “.
Any help would be greatly appreciated
lolouk44
(lolouk44)
2
try this:
{% if state_attr('sensor.glucose_value_change', 'change' ) >0 %}+{% endif %}{{state_attr('sensor.glucose_value_change', 'change' )}}
{{ "{:+.1f}".format(float(state_attr('sensor.glucose_value_change', 'change'))) }}
.1
sets it 1 decimal place, so change or remove as needed. float()
can be omitted if the attribute is already a float.
Worked like a charm. Thank you
Hi guys I just fell upon this thread and tried your solution like so:
heat_chart_yearly_compare:
value_template: >-
{% if (states('sensor.mariadb_yearly_heat_comparison') | float) >0 %}+{% endif %}
{{ states('sensor.mariadb_yearly_heat_comparison') }}
electricity_chart_yearly_compare:
value_template: >-
{% if (states('sensor.mariadb_electricity_yearly_comparison') | float) >0 %}+{% endif %}
{{ states('sensor.mariadb_electricity_yearly_comparison') }}
water_chart_yearly_compare:
value_template: >-
{% if (states('sensor.mariadb_water_yearly_comparison') | float) >0 %}+{% endif %}
{{ states('sensor.mariadb_water_yearly_comparison') }}
Unfortunately I get a unexpected space character when the plus sign is applied:
Any suggestions?
Change to (as above):
value_template: >-
{% if (states('sensor.mariadb_yearly_heat_comparison') | float) >0 %}+{% endif %}{{ states('sensor.mariadb_yearly_heat_comparison') }}
Now my conf says:
value_template: >-
Then it looks like this:
Yes you’re right, using a + symbol, the + disappears, using anything else works
Can’t help, sorry
926
+{{ states('sensor.mariadb_yearly_heat_comparison') }}
926
+ {{ states('sensor.mariadb_yearly_heat_comparison') }}
+ 926
X{{ states('sensor.mariadb_yearly_heat_comparison') }}
X926
