I’m using a Pixelblaze with a mqtt bridge. You can write new effects for a led strip on-the-fly and so the list of effects can change. In the status payload, the json message includes an array of the effect names.
Can we get a templating option for effect_list to make use of this list?
With your code, is it pulling the effects from your yaml file?
I’m using Python code to send the status of the pb and in that json there is a list of the effects. I would like to be able to update the list of effects in HA using that json output. So if I ever add/delete an effect, HA will update the list.
Doing so you connect to pixelblaze with entering IP adress in the config process. After installing this integration you have an entitiy. This entity has an attribute which holds the patterns on the device. The above code extracts the list of effects states.*.attributes.effect_list and remve the first entry … which is “SEQUENCER” for me always and thenrandomly select one, each time this service is called.
This is my full automation which does everything.
- alias: "Weihnachstbaum Mega Automatisierung"
- platform: time
at:
- &time_start "06:30:00"
- &time_end "22:00:00"
- platform: state
entity_id:
- switch.anwesend
- platform: homeassistant
event: start
- platform: event
event_type: automation_reload
- platform: time_pattern
hours: "/2"
minutes: 0
variables:
anchors:
- &target
entity_id: light.weihnachtsbaum
- &turn_off
<<: *target
alias: "Turn off christmas tree"
service: light.turn_off
- &turn_on
<<: *target
alias: "Turn on christmas tree"
service: light.turn_on
brightness: 128
effect: "Twinkly Stars"
- &change_sequence
<<: *target
alias: "Turn on christmas tree with random effect"
data_template:
brightness: 128
effect: '{{ states.light.weihnachtsbaum.attributes.effect_list | reject("==", "SEQUENCER") | list | random }}'
- choose:
- conditions:
- alias: "When house is in vacation mode"
condition: state
entity_id: switch.anwesend
state: "off"
sequence:
- *turn_off
- conditions:
- alias: "Regular change of effect"
condition: trigger
- alias: "When evening/night"
condition: time
after: *time_start
before: *time_end
sequence:
- *change_sequence
- conditions:
condition: time
after: *time_start
before: *time_end
sequence:
- *turn_on
default:
- *turn_off
Ah yes, I’m remembering now. The problem for me was I run HA on a remote server so the plugins that work with local devices don’t work. That’s why I ended up writing a Python script to control PB over MQTT. But that didn’t allow me to update the effects list within HA.
