Add ability to control light for Samsung AC using Smartthings integration
Would it be possible to add the option to turn the light on or off on the Samsung air conditioner display? It would be very useful for creating automations, especially when going to sleep so that the light isn’t disturbing. I believe this issue has been raised on other occasions. Thank you very much!
HI, I was searching for the same and wanted to raise feature request. Have you done it already? Helpful link:
I support this feature request. The AC doesn’t remember the light setting. So every time you start the AC from HA, the display turns back on. The amount of light is disturbing when you want to sleep.
I also support the request
There is also an smartthings custom version in github but that is missen other sensors i need for automations
Totally agree! I use home bridge Samsung AC just to turn off the light automatically
Could you tell me what version this is? I would like to install it if possible.
This feature was in the Veista/Smartthings alternative integration. But the project was dropped and no one PR is accepted by the Dev. Could be cool if someone bring this feature to main project.
