Add Aladdin Connect Back (Official Request from the Genie Company)
We have officially updated our SDK license to be open-source compliant, which can be seen in version 1.0.5 on PyPi here: genie-partner-sdk·PyPI
We currently do not have bandwidth to work on re-integrating it in the short-term, but were hoping the community would be willing to help us out. The SDK is the same as it was before, so the old integration should work as is assuming no breaking changes have been made to the platform APIs.
We have added this to our roadmap and if no one from the community is able to help out, we still plan on re-integrating. However, we do not have a definitive timeline of when that would be.
Thank you to everyone who has helped us up to this point, and we greatly appreciate everyone’s patience while we have been working through this with our legal team.
May I suggest you start by adding the old integration as a custom integration so people can test it?
I am interested in working on this integration. I need to get oauth credentials to start configuration.
@leetcat in order to use the integration, you must use the cloud login flow. We do not share the client credentials publicly.
@nickrout when we have time we will work on adding the original integration back. If you are available to help out, you can reference this PR: Remove Aladdin Connect integration by joostlek · Pull Request #120980 · home-assistant/core · GitHub where it was removed. If you want to test out the original integration, you can try reverting the commit that removed it.
