Add attribut from another entity to a entity card
sorry, I am new to HA and I am looking for a possibiltiy, to add a attribut from another entity to another entity.
I have some sockets with devices on it, where I also monitor the energy (watt, kWh).
Is it possible to add kw to the normal entitiy card?
This is what I got:
I would like to have this:
Greetings
Martin
  1. This is not Entity card - this is Tile card.
  2. Tile card supports displaying attributes of an entity. It is not possible to add an attribute of another entity.
Your possible ways are:
  1. If this is a template sensor added onto a Tile card - add a new attribute to this sensor, then this attribute could be added onto the Tile card.
  2. Reconsider your design for your needs, there are lot of cards (stock/custom).
  3. Create a new Feature request in Frontend github discussions - if you need to add a possibility to add attributes from different entities.
There is also a custom resource you might have a look at:
This only works with entity cards.
Thanks to you both, I will try it.
Greetings
Martin
