Add conditions to an automation
This is my automation to start a pump when the float sensor turns on
    id: 'Check Water Level In Overhead tank'
    alias:  'Time To start Pump'
        platform:   state
        entity_id:  binary_sensor.ohtank_level_low
        to: 'on'
        service:    switch.turn_on
        entity_id:  switch.ohtank_pump
I want this automation to work in the following two conditions
1…Time is after 06:00:00 or
2 …Time is after 18:00:00
How do I add these conditions?
Appreciate help on this
Best Regards…
condition:
  condition: or
  conditions:
    - condition: time
      after: '06:00:00'
    - condition: time
      after: '18:00:00'
You do realise that 18:00 is after 06:00 though?
So that condition is redundant unless you add a before: to limit the time after 6am.
condition:
  condition: or
  conditions:
    - condition: time
      after: '06:00:00'
       before: ‘08:00:00’
    - condition: time
      after: '18:00:00'
       before: ‘20:00:00’
Will this remove the redundancy.
Your example uses fancy quotes instead of standard single-quotes. Replace them otherwise it will not pass configuration check.
No: ‘20:00:00’
Yes: '20:00:00'
I am right now using my iPad, when I test it will be using my desktop.
Thanks tom_l: and 123 Taras.
I will update after it is applied in the automation.
Also remove the one space indentation of the before:'s
Are these condition lines to be added before the trigger: ?
No, after trigger: and before action: as described in the documentation: Automation Basics.
well…technically…it doesn’t matter which order anything is in. It will still work as long as all the sections are still there no matter what order they are in. That is proven by the results from the automation editor.
However, it is common practice, and it helps readability, if you do it the way taras recommends to do it.
I just wanted to mention it because you will see it in other ways in the forums when people post code created in the UI editors and it is still valid.
What’s supposed to happen at 18:00h if your binary sensor went to ‘on’ at e.g. 17:00h?
Currently nothing will happen.
I just created an automation using the Automation Editor. Here’s the YAML it produced:
Screenshot from 2020-05-23 19-53-00
The key-names within each section are sorted alphabetically but it preserves the logical order of trigger, condition, and action.
Just for fun, I rearranged the sections like this:
Screenshot from 2020-05-23 19-58-09
It passed ‘Check Configuration’. That means, yes, the order of the three sections isn’t critical but, no, Automation Editor does place them in logical (causal?) order.
Interesting…
I thought it always screwed up the other section name order too.
I wonder if I’m mis-remembering (likely) or if something has changed?
I never use the Automation Editor so I couldn’t say if this behavior is old or new (other than the alphabetically sorted keys). FWIW, I created the automation using Home Assistant 0.110.0 on an RPI3 (a new test system I recently implemented).
I’ve always used the “Core” version and so I was ‘out-of-the-loop’ when people discussed Supervisor, Add-Ons, snapshots, etc. Now I have two instances of Home Assistant running, one as an RPI3 disk-image and the other as Supervised on Ubuntu.
Hi, can you explain why nothing will happen if the binary sensor comes on at 17 :00. In this case I want the pump to come on at 18:00. Please let me know if I need to correct the logical conditions.
The trigger is that the state of the binary sensor changes - but the state does not any more, it has changed already, so: not state change, not action.
For simplicity, I’d just create a 2nd automation that checks at 6:00h and at 18:00h if the state of the binary sensor is ‘on’ already - and use the same action.
I assume you already have another automation that will switch the pump off again when necessary.
No need for a second automation. Just add a 1800 time trigger to the existing automation.
That would just turn the pump on no matter if it’s required or not, independent of the state of the binary sensor - wouldn’t it?
You put the binary sensor in the conditions as well.
Right - so @karansoi needs to add two time triggers (for 6:00h and 18:00h) and the condition that the binary sensor is ‘on’.
@karansoi - triggers are always considered to be ‘or’ while conditions, if not specified differently, are considered to be 'and.
Thanks @chairstacker and @tom_l.
Since I want my pump to run in a period of 2 hours from 06:00:00 or 18:00:00, I have modified the automation, with triggers at every 30 minutes. In the condition I have the low and high level sensors. This is my automation:
- id: Check Water Level In Overhead tank
  alias: Time To start Pump
  - at: 06:00:00
    platform: time
  - at: 06:30:00
    platform: time
  - at: 07:00:00
    platform: time
  - at: 07:30:00
    platform: time
  - at: 08:00:00
    platform: time
  - at: '18:00:00'
    platform: time
  - at: '18:30:00'
    platform: time
  - at: '19:00:00'
    platform: time
  - at: '19:30:00'
    platform: time
  - at: '20:00:00'
    platform: time
  condition:
  - condition: and
    conditions:
    - condition: state
      state: 'on'
    - condition: state
      entity_id: binary_sensor.ohtank_level_high
      state: 'on'
  - entity_id: switch.ohtank_pump
I used the automation editor to do this.
Is there another way of coding this?
