It would be great to add the current scheduled temperature to the attributes stored for a Nest thermostat (i.e., climate
sensor).
This should be easy to add as it is available via the official Google Nest API.
Use case as follows:
- Someone (e.g. significant other), manually changes the thermostat from the scheduled temperature and “forgets” to return it to the original temperature
- It would be great to then use an automation to create an alert saying that the thermostat is no longer set to its scheduled set point. This alert could be sent immediately as a notification or after a certain amount of elapsed time.
Thanks!
