Add custom words to Speech-to-Phrase
Hey,
as shown in the Speech-to-Phrase documentation, it is possible to add custom sentences.
The shown example is a perfect fit for what I would like to achieve:
language: "en"
lists:
  todo_item:
    values:
      - "apples"  # make sure to use quotes!
      - "bananas"
But this snippet is not working when it’s the only code inside config/custom_sentences/en/sentences.yaml
It shows the following error: Missing property “intents”
In my understading, this syntax only works when it’s added via the command shown in the documentation:
python3 -m speech_to_phrase ... --custom-sentences-dir /path/to/custom_sentences
But in my case, I’m running speech-to-phrase inside home assistant and can’t simply execute this command.
I want to achieve, whats already said in the documentation:
This would allow you to say “add apples to my shopping list” if you have a todo entity in Home Assistant exposed with the name “shopping list”.
Home Assistant already has a file which contains exactly the intents I’d like to use.
And speech-to-phrase also already has the phrases to add items to lists.
How can I extend these phrases by items (like apples or bananas) in home assistant?
I’d appreciate any help :slight_smile:
Update:
I have found the sentences.yaml that speech-to-phrase uses when installed as an HA addon:
/share/speech-to-phrase/train/{your language}/sentences.yaml
Maybe that’s what HA configures as the /path/to/custom_sentences for speech-to-phrase?
When adding custom todo_item values they don’t get automatically recognized and “trained” by speech-to-phrase. But when restarting the speech-to-phrase addon, the sentences.yaml gets rewritten and the custom values are lost.
My current idea:
Somehow check the docker config of speech-to-phrase and check if the –custom-sentences-dir is already set to /share/speech-to-phrase/train/{your language}/sentences.yaml, or still free to use.
If it’s not set yet, set it to a new yaml file and that might be it :pray:
The documentation of Speech-to-Phrase in the HA addon store (not GitHub!) says
You can add custom sentences to /share/speech-to-phrase/custom_sentences/<language>/sentences.yaml where <language> is…
Furthermore there is a documentation for voice control as well (but maybe not compatible with S2P):
You ever figure this out?
It seems like if you have that yaml you referenced if you located it in a file here:
/config/custom_sentences/en/todo.yaml
Speech-to-phrase should pick it up at that directory should be loaded as mentioned here (though it doesn’t seem to work): Setting up custom sentences in configuration.yaml - Home Assistant
I just figured it out. Put this file here instead and it works:
/share/speech-to-phrase/custom_sentences/en/todo.yaml
