# Balcony Door Sensor battery level
- name: 'Balcony Door Sensor Battery'
state_topic: 'helium/sensor/rx'
value_template: "{{ value_json.battery if value_json.battery is defined else states('sensor.balcony_door_sensor_battery') | round(1) }}"
unit_of_measurement: "%"
device_class: "battery"
But home assistant complains that sensor.balcony_door_sensor.battery doesnt have a default value, and I’m not quite sure how to add one.
Home Assistant gives: ValueError: Template error: round got invalid input 'unknown' when rendering template '{{ value_json.battery if value_json.battery is defined else states('sensor.balcony_door_sensor_battery') | round(1) }}' but no default was specified
The problem is that you are trying to round a string.
all states are strings so states('sensor.balcony_door_sensor_battery') becomes a string even if it looks like a number.
you need to add the float() function to convert it to a float value:
value_template: "{{ value_json.battery if value_json.battery is defined else states('sensor.balcony_door_sensor_battery') | float() | round(1) }}"
but that still could give you the same error if the value of sensor.balcony_door_sensor_battery hasn’t been initialized yet.
That wouldn’t be a big deal for me if it only happened at startup when things aren’t fully initialized becasuse once things do get initialized then the template will work normally.
But I know sonme are OCD about errors in the logs so if you want to fix it you will need to figure out what you want as a default in the template:
value_template: "{{ value_json.battery if value_json.battery is defined else states('sensor.balcony_door_sensor_battery') | float(some_default_number_here) | round(1) }}"
