How do you enable the Supervisor sensors? I can’t find it anywhere and the docs simply say that they are disabled by default. Not very helpful at all.
I was not referring supervisor sensors. But add-on sensors. You find them via the “configuration->devices&services” menu.
Then open the services of the supervisor integration. Each add-on is a device there. Then select the add-on you want to enable sensors for
