For the Let’s Encrypt plugin i need support for den DNS provider INWX.
I already implemented the support for INWX in the Let’s Encrypt plugin.
https://github.com/XantXant/addons
For INWX i added the certbot-dns-inwx plugin for certbot.
But i have a problem to test it before i make a pull request.
First i tried to test it with Docker and VSCODE plugin, but there i get:
“Timeout while waiting for docker to come up”
Because of the problem with bootstrap script and WSL 2.
I have no solution for this now.
Then i tried to test it with a local build on the raspberry pi with HAOS.
But the build failed at running build_rust with error: can’t find Rust compiler
So i need a little help and i can add this feature.
