Hi! ![]()
Unfortunately, the default WLED Nightlight switch in Home Assistant doesn’t support passing a custom duration like &NL=10. It simply toggles Nightlight using the default value set in the WLED UI (similar to &ND).
However, if you want more control — like setting duration, mode, target brightness, and even reading remaining time — this is possible using my WLED Live View Proxy integration, which supports sending JSON commands via WebSocket.
Example service call with full parameters:
service: wled_liveviewproxy.send_command
targets:
entity_id: light.wled_strip
command: {"nl":{"on":true,"dur":10,"mode":1,"tbri":64},"v":true}
This enables Nightlight for 10 minutes with fade, like &NL=10.
The "v": true" flag returns the full WLED state, including nl.rem — the remaining duration in seconds.
More details and examples:
WLED Live View Proxy for Home Assistant
