It would be useful to have an option to disable entities from tracking (saving data to the database).
I know that it can be done manually, but it’s a lot of work ( Recorder - Home Assistant ).
You could add a switch to the UI to the options view that would disable saving.
It could even be done in such a way that it would simply add or remove this entity from “recording” yaml section.
Each integration adds many entities. Often only a few of them are used and the rest are disabled. But they are still saved in the database. The database is growing terribly (I know, I can clean it from time to time). SD cards are also being killed (I know, I can save a little less often). there is high resource consumption.
