I start with home assistant and for some time now I’ve been trying to install it on a raspberry pi4 with ubuntu server 20.10 where there are already several dockers :
nextcloud
ghost
apache+php for my custom applications
mariadb
all behind traefik + letsencrypt using docker-composer
I made a first try by adding in docker-composite home assistant and after some configuration tests by adding labels I succeeded in making home assistant work successfully in https in a sub-domain.
But as a beginner in home assistant I thought that the supervisor would facilitate my beginnings.
The installation went well I can access HA with myIP:8123 or sub.domain:8123 but I don’t understand how to configure traefik to access with “https”://sub.mydomain as I did with docker-composer.
I tried to add the necessary labels in the homeassistant container but it doesn’t work.
So my questions :
is there a way to install HA supervised with a docker-compose-based method ?
or do you have an example configuration of traefik + letsencrypt that works with homeassistant/supervised-installer ?
Thank you in advance for your help, because I’m running out of ideas …
Have you figured this out? I have the same question. I’m able to install non-Supervised Home Assistant container and get that working with Traefik. But I was hoping to move to Supervised to have the Add-On store and easy backups.
with this configuration I can access home assistant from outside with https://homeassistant.mydomain.com
and from my local network with http://my_local_ip:8123
a traefik expert might find fault with it, but for me it meets my needs.
@fbollon I am new with traefik and I want a similar install as you did. Any chance we could get in touch or your could share your full docker-compose as well as other configs plz.
