I have Grafana installed on my Home Assistant Green device. I want to use the default SQLite DB as a data source. However, when I attempt to “Save & test” the connection with the path to /config/home_assistant_v2.db
and the path prefix set to “file:”, I receive the following error:
error checking db: error checking for valid SQLite file: unable to open database file (14)
When I run ls -l /config/home-assistant_v2.db
, I see
-rw-r--r-- 1 root root [date] /config/home-assistant_v2.db
Why can’t Grafana add the SQLite DB as the data source?
