I used the ZHA integration. After searching and adding the device, I looked at what signature the device has, it is as follows:
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0301",
"input_clusters": [
"0x0000",
"0x0001",
"0x0004",
"0x0005",
"0x0006",
"0x000d",
"0x000f",
"0x0201",
"0x0204",
"0xef00"
"output_clusters": [
"0x000a",
"0x0019"
Some trials showed that 2 switches mean BOOST and LOCK, I don’t know the third one. Then there is one Binary Sensor, and it is still false for all five heads.
It is also interesting that LOCK only works for me on two of the five heads. For others, it will randomly turn on or off by switching this feature to a different head than the target one.
