Add IT function to rfxtrx component
Home Assistant release (hass --version):
I’m using HASS version 0.35.3
Python release (python3 --version):
Python 3.5.2
Component/platform:
Docker container on Synology DSM 6
Description of problem:
Since today i own the RFXcom rfxtrx
I managed to add my Klik aan Klik uit switches.
Now i’m trying to add my Flamingo FA500 switches.
When i add the following lines to the config:
switch:
  platform: rfxtrx
  automatic_add: True
and press on on the remote i get 2 codes
Here the log entries:
16-12-28 17:04:06 INFO (Thread-13) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: 001f2042 Class: LightingDevice Sub: 0)
16-12-28 17:04:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.0b1100000001f20402000070, old_state=<state switch.0b1100000001f20402000070=off; friendly_name=0b1100000001f20402000070, assumed_state=True @ 2016-12-28T18:04:04.932438+01:00>, new_state=<state switch.0b1100000001f20402000070=on; friendly_name=0b1100000001f20402000070, assumed_state=True @ 2016-12-28T18:04:06.329269+01:00>>
16-12-28 17:04:06 INFO (Thread-13) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: a11 Class: LightingDevice Sub: 1)
16-12-28 17:04:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.07100101410b0070, old_state=<state switch.07100101410b0070=off; friendly_name=07100101410b0070, assumed_state=True @ 2016-12-28T18:04:05.287064+01:00>, new_state=<state switch.07100101410b0070=on; friendly_name=07100101410b0070, assumed_state=True @ 2016-12-28T18:04:06.684900+01:00>>
16-12-28 17:08:48 INFO (Thread-13) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: 9ddd6632 Class: RFXtrxDevice Sub: 10)
16-12-28 17:08:51 INFO (Thread-13) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: 9c6d5032 Class: RFXtrxDevice Sub: 10)
16-12-28 17:08:52 INFO (Thread-13) [homeassistant.components.rfxtrx] Receive RFXCOM event from (Device_id: 001f2045 Class: LightingDevice Sub: 0)
16-12-28 17:08:52 INFO (Thread-13) [homeassistant.components.rfxtrx] Automatic add 001f2045 rfxtrx device (Class: LightingDevice Sub: 0 Packet_id: 0b11002b0001f20405010f70)
When i try to turn them on/off from hass it is not working.
I have looked around and with Domoticz it is working, here some info from RFXcom
Switch fa500_remote_A { rfxcom="<2622466.1:Command" }
Switch fa500_remote_B { rfxcom="<2622466.2:Command" }
Switch fa500_remote_C { rfxcom="<2622466.3:Command" }
Switch fa500_remote_D { rfxcom="<2622466.4:Command" }
// Note: does not mimic the remote but uses another subtype and code which
// should be learned to the socket separately
Switch virtual_fa500s_switch_1 { rfxcom=">2061.1:LIGHTING5.IT:Command" }
Switch virtual_fa500s_switch_2 { rfxcom=">2061.2:LIGHTING5.IT:Command" }
Is it possible to add the IT functionality to hass? Thanks
Someone (probably you) have to add the support here: https://github.com/Danielhiversen/pyRFXtrx
