It would be great to have a ‘Notes’ section available in the UI for other household members that want to use Home Assistant, but aren’t as technical as the admin. I’d like to be able to have either a sidebar section or a custom card that I could use to make it easy for a non-technical user in my household to control the many things I have setup within Home Assistant, without them having to learn about Home Assistant administration themselves.
You can use the Markdown card to create a custom Notes card. I do this every time I help someone get set up with HA.
UI is like a joke. If you have to explain it, it’s not that good.
Good to know! Thanks!
I don’t have a bunch of simple things in my setup and the other household members aren’t tech savvy at all.
My setup is far away from simple as well, however that doesn’t mean the UI controlling it can’t be intuitive and simple.
Also doesn’t mean you can’t have notes.
