Add-on: Home Assistant Google Drive Backup
I would say, check the Google drive backup configuration to be sure everything is still as you want it.
Thank you. I think this is now working as it was before.
I restored my Home Assistant using a full backup but I can’t find the new web ui for the Home Assistant Google Drive Backup it’s not showing in my connections on my router either any advice?
Many Thanks
Hello everyone, is it possible to exclude the media folder from the backup with all its contents? The problem is that I have immich installed (for storing photos), and it makes a full backup of my photos every time, but the Google Drive is not enough.
Yeah, just setup your backup as a ‘partial’ and don’t tick the box for the Media folder
I just want to thank you for making a task that could potentially be fiddly and result in errors, to one that is simple and effective to set up! Thank you!
