Add on "Roku" - when I do this, it cannot find my Roku based on the IP Address
I’m new to Home Assistant and found that https://www.home-assistant.io/integrations/roku/ can be added into it. I’ve gone to it to add, but when I put in the correct IP address, it says it cannot connect.
I do have pfSense setup, but I can ping the IP address it is on.
Anyone have thoughts of what could be the issue?
Thanks, Michael
You do realise that “Roku” isn’t an IP address?
Yes, I put in my IP address and gets the same error. I have in pfSense showing that as the host…so I thought i’d try that.
Do this first
